best springs for heads
Old Jul 1, 2007 | 01:37 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
i want to buy springs for my heads. what would be the best one for me. to go in my trick flow heads and need to hold 550 lift.
Old Jul 1, 2007 | 09:20 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
Re: best springs for heads
I am going with Comp Cams Beehive springs to on my Trick Flow G-2 heads along with their retainers and locks. I am using Trick Flow's hydraulic roller camshafts with Comp Cams retro hydraulic roller lifters. With the articles I have read on the Beehive springs that some of the professional engine builders did, they do work without causing some the problems that come with conventional dual spring setups for higher lift cams and actually picked up nearly 40 hp over conventional spring setups.
gta90
Sep 15, 2015 04:00 PM
gixxer92
Sep 1, 2015 04:32 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
anesthes
Aug 8, 2015 09:37 PM
