piston and rod measurements
Old Jul 1, 2007 | 07:32 PM
alabama_lowlife's Avatar
Car: nissan titan and nissan hardbody
Engine: 305 tpi
Transmission: manual
i've been looking all over for specs on a typical 350's piston and rod. the diagram below is for a dodge v6 and i need the comparable chevy measurements for the rod length, piston diameter, whatever...not everything in this drawing, but most of the stuff in it. does anybody have a rebuild manual or know what the measurement are? i'm sure some of the stuff varies but just the most common will work.
Old Jul 1, 2007 | 10:45 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: piston and rod measurements
what in the world are you talking about... what does a dodge v6 have anything to do with a SBC
but the typical SBC rod is 5.7 inches measured from the center of the big end to the center of the small end...
but pistons are a different story they can come in many sizes..
from 4"-4.060"+ then there is compresion distance normaly about 1.561" or so but that is dependent on the rods they will be used on....
WHAT are you really asking
Old Jul 2, 2007 | 05:14 AM
Engine: 305 tpi
i'm asking for the comparable chevy measurements for the measurements shown in the drawing. i'm getting a tattoo similar to the drawing and i want the measurements to be accurate (for a typical 350) since they will probably be legible. i know the dodge v6 doesn't have anything to do with a chevy....but that's the only drawing i can find that represents what i want it to look like lol
Old Jul 2, 2007 | 11:28 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Gasket thickness - .015 average (stock gasket)
.039 aftermarket
Compression height - 1.56"
Block height, 9.025" (stock) or 9.00" decked
Rod length - 5.7"
Stroke - 3.48" (or 3.75" for a stroker motor)
Cylinder bore 4.00" (or say 4.030 for a rebuilt one)
The measurement in the top right that isn't labeled is probably the deck height, so that'll be ~.025"
I don't know the bearing sizes/ journal sizes off the top of my head.
Old Jul 2, 2007 | 04:33 PM
Engine: 305 tpi
you're the man!
btw my son loves all your games lol
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
AUZ28
Oct 3, 2015 06:28 PM
