comp cams XE268
Old Jul 3, 2007 | 10:15 PM
scottyb123's Avatar
Car: 84z
Engine: 305 HO carb
Axle/Gears: stock
comp cams XE268
i hear of a lot of people using this cam in a 305...how does it work, annd what are yalls overall impression with the cam?....much performance gains?.....better sound?.....im probably gonna get this cam and wanted some feedback.
Old Jul 10, 2007 | 03:43 PM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
Re: comp cams XE268
What are the specs?
I install a cam from Doug Herbert Cams
214-223 @ 0.050", .500" lift, 104intakeCL, 112 separation. Runs great with 15"of vac and stock computer and a superchip. I'm running a 200r4 and 3.73 in the rear! HO 305 with CCC
q-jet...Have to recalibrate the carb though!!
Old Jul 10, 2007 | 04:08 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The XE268 is a pretty good cam. The valve lift is below the typical .480" limit on stock heads, and opens & closes the valves quicker to provide better cylinder filling. But, you also need better valve springs than stock.
"Better sound"? What's "sound" got to do with it?
It'll wake up your L69. Sorry to hear you're running an Edelbrock carb, though.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
sandman92084
Sep 12, 2015 10:27 PM
Strick1
Sep 4, 2015 07:11 AM
