different firing order
Old Jul 5, 2007 | 08:03 AM
pdrinkut's Avatar
Hi all, I was changing the spark plugs on my 89 camaro iroc-z 305 tpi, and noticed that the firing order that is on the car is completely different then whats in my Hanes book and what I can find online. I wrote down the order that they were in and then changed the order according to what "official" documents I could find. The car didn't start, it seemed to try but wouldn't, I put the firing order back to how it was and the car fired right up, it ran really rough but it ran. Was there different firing orders for this car or is there something else going on with mine? If anyone can give me any advice that would help I'd appreciate it. Thanks
Old Jul 5, 2007 | 08:28 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: different firing order
AFAIK the firing order hasn't changed in eon's on the SBC 350. Your firing order should be 18436572.
Are you 100% sure that your wires are not crossed? 100% sure that what you believe to be the number 1 post on the distributor IS the post designated for cylinder number one according to the rotor?
My suggestion to you is to put your engine at #1 TDC compression stroke, pull the distributor, and see where you're at. #1 post isn't always in the location that the manuals state. No matter where #1 is though, the firing order remains the same.
Old Jul 5, 2007 | 08:46 AM
jtrescot's Avatar
Car: 88 GTA
Engine: 355
Transmission: TH350
Axle/Gears: 3.42 Auburn Pro
I have seen aftermarket distributor caps that reorder the wires to clean up their routing. Maybe you have one of these?
Old Jul 5, 2007 | 11:57 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I've seen lazy people stick in the dizzy off and just route the wires 'off', firing order is the same, post locations just change.
Old Jul 5, 2007 | 12:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which one of these firing orders do you have?
1 8 4 3 6 5 7 2
8 4 3 6 5 7 2 1
4 3 6 5 7 2 1 8
3 6 5 7 2 1 8 4
6 5 7 2 1 8 4 3
5 7 2 1 8 4 3 6
7 2 1 8 4 3 6 5
2 1 8 4 3 6 5 7
Old Jul 6, 2007 | 07:24 AM
pdrinkut's Avatar
I had the thought that it might be somesort of after market distributor that could have changed the post locations but I wasn't sure how to check. This might sound a like a stupid question but how do I put my engine at the #1 TDC compression stroke?
Old Jul 6, 2007 | 07:33 AM
The firing order is the same as any other SBC. 18436572. You can believe that.
Most people who think their firing order is wrong, don't know which cyl is which (been working on Frods or something). #1 is front left, other odd #s are down the left side; #2 is front right, the other even #s down that side.
To find #1 firing, put a piece of hose or something in the #1 spark plug hole; bump the starter in small increments until you hear compression escaping; bump it over SLOWLY and CAREFULLY or turn it by hand (but NOT by using the crank damper bolt) until the timing marks are 10° or so before lining up.
Old Jul 6, 2007 | 07:47 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
As stated above, #1 can be anywhere on the distributor. It depends where the rotor is pointing when #1 cylinder is at TDC.
Looking down on the cap, the order or rotation is clockwise.
It's very common to mix up #5 and #7 cylinders because they are beside each other on the distributor cap and head.
Old Jul 6, 2007 | 03:28 PM
klez's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L Ported SLP Runners and Intake
Transmission: 700r4 w/ shift kit
for some reason, on my 1988 GTA the order its at now is 16532784 and it runs, but not that well.
i have the stock distributor and i just replaced the cap and rotor.
what should i do? just leave 1 where its at and fix all the others?
Old Jul 6, 2007 | 03:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Tear them all off and start over.
Old Jul 6, 2007 | 03:58 PM
klez's Avatar
so let me get this straight, i need to find TDC, then look at the rotor and whichever post its going to strike next (when at TDC) is where i need to put the wire from my #1 cylinder and then just go from there with 8436572
is this right?
Old Jul 6, 2007 | 04:03 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Pretty much, just make sure you're at TDC after the compression stroke instead of TDC after the exhaust stroke.
Old Jul 6, 2007 | 06:57 PM
Right... don't forget, they go in that order CLOCKWISE around the dist cap
Old Jul 6, 2007 | 09:30 PM
klez's Avatar
i just had 3 of them mixed up....dont know how, but they are all good now ;]
Old Jul 6, 2007 | 10:32 PM
HotRodLarry's Avatar
Car: '83 Z28
Don't forget.. some aftermarket race cams switch cylinders # 7 and 4. But since the issue was fixed, this wouldn't apply.
Old Jul 7, 2007 | 12:56 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Those cams aren't found so often in the wild.
Old Jul 22, 2007 | 09:28 PM
pdrinkut's Avatar
Ok, so I found my TDC and rewired the distributor according to the which post was number one. The car still wouldn't start, so I hooked up a timing light between the ignition coil and the distributor cap and tried starting, there was no spark, so the next thing I did was replace the ignition coil thinking it was bad, hooked up the timing light again and still no spark. So now I"m guessing that it's something before the ignition coil. If anyone has any help at this point I could use it.
Old Jul 23, 2007 | 12:23 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
is your pink wire still plugged into the dist.?
Old Jul 24, 2007 | 09:20 PM
pdrinkut's Avatar
There's two plugs with a pair of wires in each plug connected to the distributor in what I'm guessing is the ignition module. I can't really tell what colors they are one seems to be pink or red.
KCG
Jun 24, 2020 04:33 AM
djmarch
May 8, 2016 11:32 AM
camarohelp
Sep 22, 2015 03:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
