Strange Idle
Old Jul 6, 2007 | 01:36 AM
86z28305's Avatar
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
Strange Idle
When I start up my car it idles at 1800 rpm then when its warm it idles at about 1500 when I give the throttle a couple of quick pumps it will drop to 1000 and if I do it again usually it drops down to a nice 700 rpm but, It doesnt stay there after I have to give it gas it shoots back up to 1500 rpm at idle and sometimes higher in park. Whats going on?? Vacumm Leak??
Old Jul 6, 2007 | 01:42 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Strange Idle
Sticking throttle blades.
Old Jul 6, 2007 | 01:19 PM
86z28305's Avatar
Re: Strange Idle
How do I fix that?
Old Jul 6, 2007 | 01:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Strange Idle
Try cleaning the throttle body and linkage to see if it frees things up first.
Old Jul 6, 2007 | 01:34 PM
86z28305's Avatar
Re: Strange Idle
Ok thank you I will get back soon with the results
Old Jul 9, 2007 | 05:48 PM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
Re: Strange Idle
Hi....Take a screw driver...break the screws loose on the the throttle blade and tighten them back up! Sometimes just a slight repositioning will work!!
Old Jul 11, 2007 | 10:53 AM
86z28305's Avatar
Re: Strange Idle
Thank you i cleaned the throttle blades and the throttle body it helped a little bit, ill loosen the screws and get back with you
86IROC112
Nov 27, 2015 09:54 AM
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
