Will Exhaust Return tube coming up from Cat melt Plug Wires?
Old Jul 10, 2007 | 10:20 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
I just got finished re-routing my plug wires using a wire loom and the way they wrap around the back passenger-side corner of the block they touch the exhaust return tube from the catalytic converter. You know, the one for the A.I.R. system. I've tried to fix it so they don't touch but I can't do it, the wires aren't long enough to route any other way. Do you guys know if they will melt from touching this tube or not? Thanks..
Old Jul 10, 2007 | 11:30 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Will Exhaust Return tube coming up from Cat melt Plug Wires?
That AIR tube going from the air pump to the cat is pumping cold air TO the cat, not hot exhaust from the cat. You'll be fine.
Old Jul 11, 2007 | 12:29 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Thanks! I had me worried.
1992 Trans Am
May 10, 2023 07:19 PM
tnrednneck
Aug 13, 2015 08:57 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
djmarch
Aug 9, 2015 05:27 PM
