Just how much of a PITA is it to replace the rear main seal?
Old Jul 7, 2007 | 11:57 PM
Mongoose's Avatar
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Mine has started leaking and I'm considering doing it myself but if it's major enough I'll let a local shop do it.
Old Jul 8, 2007 | 12:02 AM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Re: Just how much of a PITA is it to replace the rear main seal?
Remove trans, remove flywheel, R&R seal. If that sounds like a PITA then let your shop do it.
Old Jul 8, 2007 | 12:43 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
It is a pita to R/R the rear main seal especially if it's still sitting inside the car. If you plan on installing headers or upgrade the engine, wait until you have all the parts and do it all at once.
Old Jul 8, 2007 | 01:30 AM
urbanhunter44's Avatar
Car: '72 Chevy Nova
Engine: Solid roller 355
Transmission: TH350
Axle/Gears: 8.5" 10-bolt 3.73 Posi
It's not bad at all if you have a bit of experience. If you dont have any experience or someone to help you, you may wish to have a shop do it.
Old Jul 8, 2007 | 08:24 AM
Mongoose's Avatar
Car: 90 Formula
Thanks for the replies. The experience is there but I'm short on spare time with work and work on my house so it may wind up at the mechanic's.
Old Jul 8, 2007 | 01:20 PM
Synful's Avatar
what does installing headers have to do with anything....
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
Reborn756
Sep 4, 2015 03:42 AM
Exxon Limited
Aug 9, 2015 08:13 PM
Leggman1
Aug 6, 2015 04:15 AM
