bigger springs for comp cam?
Old Jul 9, 2007 | 08:02 PM
TAtothefloor's Avatar
i have a comp cam and they reccommend a set of their springs i was wondering if they are necessary or if stock springs will work because its not that agressive of a cam. i have a 89 just rebuilt 350 tpi with new springs in the rebuilt heads i dont plan on running any higher than 5500 rpm the max max will it work? also does anyone know what the spring pressure is on stock springs?
thanks
brendon
Camshaft Specification Table
Part Number12-268-4 Engine1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS XE268H-14 DescriptionIntakeExhaustValve Adjustment0 0 Gross Valve Lift0.479 0.48 Duration At 0.006 Tappet Lift268 280 Valve Timing At 0.006 OpenCloseIntake24 64 Exhaust78 22 These Specs Are For The Cam Installed At 110 Intake CLIntakeExhaustDuration At 0.05 224 230 Lobe Lift0.319 0.32 Lobe Separation114 Recommended Valve Springs983-KIT
Old Jul 9, 2007 | 08:23 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: bigger springs for comp cam?
I am running the same cam with new stock springs. Friend is using the cam with used stock springs. Those springs arent needed but i sudgest getting new stock ones. My motor has been 6500 and no valve float, although that was an accident.
Old Jul 10, 2007 | 08:40 AM
thanks for the post
Old Jul 10, 2007 | 09:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Personally, I would never use stock springs with an aftermarket cam, and would certainly replace the retainers to get rid of those heavy exhaust rotators.
Old Jul 10, 2007 | 11:25 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Thee extreme energy cams are much more agressive than a "stock" cam or a factory high performance cam. You should run a spring that will keep the valvetrain in control at high rpm. I would remove and check the seat pressure of your springs on your rebuilt heads. You need about 90 to 115 lbs seat pressure for these cams. A "stock" gm spring only has about 60lbs seat pressure. it will run but probabily will give up some power at high rpm to early valve train float. Any good local auto machine shop can check the spring pressure for ya. I would use a Comp 981 spring at minimum. This is a "Drop on replacement" spring with no machining required. I would check and adjust the installed height to 1.70" to 1.73" If shimming is required use Comp cams shim pack#4753
You can go ahead and use the stock GM springs if you just have to. They will physically fit and run fine (at low rpm) but...But don;t expect the valvetrain to do what its claimed to do with the Comp extreme cam. (make more power)
if your springs are not up to snuff just sell them off to some one rebuilding a "stock motor" to finance the cost of the new proper springs.
Other good stock diameter high perf springs that will work are Lunati 73943 Isky 205D Crane 99848 , Elgin/Pioneer RV1943X
The Comp 981 springs are less than $70 retail so you really have no reason to not "do it right" the first time.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
LT1Formula
Aug 20, 2015 09:36 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
