Help! My idle mixture screws dont do anything anymore.
Old Jul 10, 2007 | 07:44 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
So I just got my new 383 running recently and thought I had a good handle on the tune but then today I was driving home and it started to idle rough. A little smoke started to come out the tailpipes (rich black not oil blue). So then I get it home with no other real symptoms and let it cool so I can check things out.
So I went out and started it and it seemed to idle a little high but smooth after getting cool so I could touch the motor. So I started by trying to reset the idle mixture with the screws and discovered I could seat both of them and the motor seemed to run fine!!! I have no idea what to look for but I suspect there is some sort of fuel leak that is keeping the thing running.
Help!
Oh sorry this is not my car motor its a Q-jet 383 with no computers at all.
Old Jul 10, 2007 | 08:30 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Help! My idle mixture screws dont do anything anymore.
check for air leaks ,run both screws in ,with filter off place hands over top of carb.should cut right off ,if not you have an air leak ,the running rich sounded like the float was stuck,while cooling extra gas ran in manifold and evaporated hope this helps,jimmy
Old Jul 10, 2007 | 08:37 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
but if I run both the screws all the way in how could it even run? when I did that it idled like it was fine at about 900 rpm...
Old Jul 10, 2007 | 08:48 PM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
It sounds to me you have a vacuum leak and posibility of floats sticking. Check your primaries and secondaries and make sure they are not dripping fuel.They should not be wet inside your carb . You might have a dirty needle valve causing one to stick open and fuel getting bye. You just did an engine swap and it does not take much to get a needle valve sticking. After you shutt your motor down watch from top of carb and see if it is getting wet on either primaries or secondaries.
Old Jul 10, 2007 | 09:03 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Will do.
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
