out of time?
Old Jul 13, 2007 | 09:58 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
out of time?
well it will just crank over and do nothing,but if i dump gas down tbi it will crank twice ,and not want to turn over to good so im thinking its 180 out?well turned distributor around dump gas down it now it backfired through exhaust.
Old Jul 13, 2007 | 11:44 AM
DLV555's Avatar
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
Re: out of time?
If you dumped gas down the tb and it fired then it's obviously a fuel problem, not a spark problem. Turning the distributor would do nothing but possibly damage something. Make sure your injectors are firing properly and make sure your fuel pump is priming.
Old Jul 13, 2007 | 01:04 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: out of time?
yea i have a 89 gmc jimmy and the same thing happened to me a while back. it would turn over fine but would only run when i poured gas down the tb. turned out fuel pump was gone. and ill tell ya dropping a 31 gallon tank that was almost full is not fun.
Old Jul 13, 2007 | 01:34 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: out of time?
yea i realize now it was a fuel problem to begin with ,but now that i put a new dissy in it i don't know if i got it timed right.
Old Jul 13, 2007 | 03:29 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
Re: out of time?
yeah it was 180 out.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
