how good will this set-up do?
Old Jul 14, 2007 | 02:00 AM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
ok i just got some new parts and was wondering about hp numbers---
this is going onto this motor--http://store.summitracing.com/partde...splayPrice%7C0
now here are the parts that will be in it---
cam-http://store.summitracing.com/partde...K&autoview=sku
heads-http://store.summitracing.com/partde...5&autoview=sku
intake-http://store.summitracing.com/partde...1&autoview=sku
carb-http://store.summitracing.com/partde...5&autoview=sku
dizzy--http://www.jegs.com/webapp/wcs/store...55778_-1_10679
coil-http://www.jegs.com/webapp/wcs/store...47804_-1_10681
sorry this is so long, wanted to put all of my parts on here. this is going into a 91 camaro with a 700r4, 3.73 posi.
Old Jul 14, 2007 | 11:05 AM
masseyiroc's Avatar
Car: 87 irocz
Engine: 406
Transmission: th400
Axle/Gears: 4.10
Re: how good will this set-up do?
id just build a short block rather than tear a crate motor all apart for the money its worth u could have some real good parts inside(good pistons,rod bolts at least). it would be like a 400ish hp motor. u dont need a coil either the dissy comes with a good one.
Old Jul 14, 2007 | 12:19 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
I have the same heads/intake/gears and a 215/215 roller cam, just a touch smaller than yours but with more lift. I just ran a series of 13.0's at 108.
Old Jul 14, 2007 | 09:47 PM
plumminfool's Avatar
Car: 1988 camaro sport
Engine: 355
Transmission: 5 speed
Axle/Gears: Ford 9 inch - 4.11 gears
I would estimate 315-330 hp. I ran a similar combo with a bracket master cam that spec'd at 455 lift, a little bigger head, (200cc), a demon 750 dp, air gap intake, and long tube headers. Made 327 hp and ran 12.47 with a 5 speed.
Old Jul 15, 2007 | 01:04 AM
so a 750 carb won't be too big for this combo? would a 600 or 650 work better?
Old Jul 15, 2007 | 08:14 AM
Pat Hall's Avatar
I'd say a 650 carb would probably suit it better with the cam you're looking at. Those heads have some really nice flow potential though, and you could probably do them a lot more justice by going with a larger cam. I'd be looking at cams around 292 adv. duration and lift around 500 personally.
Old Jul 15, 2007 | 09:02 PM
327???'s Avatar
I'm currently running a 600 but feel that it's under carbed, I got a 750 so I'll try that to see if I can get 12's on street tires.
Old Jul 15, 2007 | 10:42 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
i would stay away from that cam
i apologize for not being an expert on what im abotu to quote, someone maybe can elaborate for me, but you want a cam with ideally as little difference between advertised duration, and actual duration.
the amoutn of degrees between the two is time the valve is spent just cracked open and not contributing anything to the motor.
im running a comp cams grind thats advertised at 274 and is actual 224/230, that lunati grind si 284 with an actual 118
on top of that the lift numbers are incredibly low, with stock rockers i get lift around .515
based on what ive read thats not exactly an ideal cam
EDIT: and whats with the springs on those heads?
Maximum Valve Lift (in): 0.480 in.
that umm sucks, not sure how else to put it. On a quality aluminum head you should be able to get valve lift up to .600
Old Jul 15, 2007 | 10:51 PM
327???'s Avatar
he is looking at a flat tappet cam, they have way less lift compared to a roller for the most part because the lobes will self destruct under the spring pressure required to control the valves if they are too aggressive.
it's also difficult to compare adv duration numbers across different manufacturers because there is no set way to do it, some companies use duration at .006, some use .001, there are others too.
he's also a spring swap away from .600 lift.
Old Jul 16, 2007 | 06:33 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ah makes sense
i fully dont understand tho how you can make power with a motor only going to .50 lift tho, when the heads flow to .540 out of the box
but im not expert on flat tappet
as for those heads just dont buy that package, youll need to buy springs all over again, get some better springs thatll take some abuse
Old Jul 16, 2007 | 07:55 PM
327???'s Avatar
yea, i would go with at least the 1.47(not dual springs) springs if your going to run a flat tappet.
OP-is your block a roller block?
Old Jul 16, 2007 | 09:19 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
That's a terrible idea there.
Buy a short block, not a complete engine, if you're buying heads, intake
, cam.
The heads you chose are good.
That cam sucks, skip it.
That intake is good.
That carb isn't worth the cash - you've got loads of q-jets at the wrecker for cheap that'll do the same thing. If you're going to spend the cash get a double pumper from holley or demon.
Old Jul 17, 2007 | 01:11 AM
i already have that motor, i am wanting to put these parts onto it, so getting a new motor is out of the question
Old Jul 17, 2007 | 03:33 AM
Pat Hall's Avatar
Picking a flat tappet cam is definitely a different ball game from picking a hydraulic roller. I'm running the cam posted in the link below in my 69 Camaro with a 355 sbc, 3.73 gears, Holley 650DP, Weiand X-Celerator #7546 single plane intake, and fully ported #462 casting, 2.02/1.60, 62cc fuelie heads. You're going to have a lot better flowing heads than what I have, and even with the old-school fuelies, my motor absolutely screams with this cam. From 1800-6000 rpm, it pulls like a freight train. Even with the single plane intake, it'll roast the tires til they blow. It'd probably work great with that Performer RPM too. This cam is probably old technology compared to some of the new Lunati Voodoo grinds and the Comp Xtreme energy series, but I've had no complaints with it. Anyways, take a look at the specs, and look for cams with similar numbers. Since you're running an auto trans, you'll want to make sure to match up a good convertor with it too. http://store.summitracing.com/partde...4&autoview=sku I also used the Crane High Intensity lifters. They're variable duration just like the Rhoads lifters, which help boost low end torque and engine vacuum without sacrificing any top end. Here's the link for those: http://store.summitracing.com/partde...6&autoview=sku I'm no genius on cams, but I figured I'd post the setup I'm using just as a starting point/suggestion for you. Hope it helps.
Old Jul 17, 2007 | 04:14 AM
what size of converter would be good?
Old Jul 17, 2007 | 12:27 PM
327???'s Avatar
I wouldn't go lower than 2500rpm.
Is the block a roller block?
Old Jul 17, 2007 | 12:55 PM
no not a roller
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
