To seal or not to seal - that is the question
Old Jul 16, 2007 | 11:04 AM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey Ya'll - Ready to install aluminum heads on my finished short block. I'm using Fel-Pro 1010 non - brinelling ( or so advertised ) head gaskets. I've
got two differing opinions on these gaskets. First guy: no gasket sealer is
needed and no retorqueing is needed. Second guy: Permatex aviation
gasket seal both sides of gaskets and no retorqueing. Which is right?
Your knowledge and assistance is always greatly appreciated!
" Ain't that a kick in the head "
Frank Sinatra - 1959
Old Jul 16, 2007 | 02:25 PM
Synful's Avatar
Re: To seal or not to seal - that is the question
permatex aviation sealant both sides
Old Jul 16, 2007 | 02:56 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Or no sealer.
Old Jul 16, 2007 | 03:05 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
Or Permatex Copper spary... Just though I'd throw another one in there. That's what I used on my aluminum heads with no problems.
Old Jul 16, 2007 | 04:43 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I didn't think you were supposed to use any sealant on head gaskets.
A high tack or copper spray can be used, basically to hold it in place - but with dowel pins, I really don't grasp why you'd need it.
This is a .039" thick steel core laminate style, meant for AL heads - for those who don't want to go look up the 1010.
Old Jul 17, 2007 | 07:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
For those I wouldn't bother with sealant.
I used the fel-pro 1094 with copper spray on mine but all this gasket is is a shim.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
NiG
Sep 2, 2015 06:54 AM
gixxer92
Sep 1, 2015 04:32 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
