Please Help my GTA won't run and I'm stumped
Old Jul 16, 2007 | 03:14 PM
Cragar87's Avatar
So first off, if this has been asked a million times before sorry, go ahead and delete this and I'll go back to searching.
Anyways I have a 91 GTA with the L98, with around 91,000 miles on it. I bought it not too long ago. When I drove the car prior to buying it, it ran hard and would go WOT no problem. However, 30 minutes after that I was driving it home and the car lost all power and began to backfire. The car would bog down and wouldn't get up above 30 MPH regardless of throttle position, but would suddenly surge randomly.
Since that time I have changed the spark plugs and wires (crappy 7mm), adjusted the timing, put a new water pump on, flushed the coolant, and checked for vacuum leaks.
I've been reading and reading and I'm thinking maybe my fuel filter or O2 sensors might be screwed up? any ideas would be great, if I don't get it running soon I'm cutting my losses. Thanks.
Old Jul 16, 2007 | 03:22 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: Please Help my GTA won't run and I'm stumped
check your fuel pressure. check your timing make sure the dis. is tight and hasn't moved when you where driving it. any check engine light?
Old Jul 16, 2007 | 03:33 PM
Cragar87's Avatar
The SES light came on for a minute but went away and hasn't come back since.
Old Jul 16, 2007 | 03:38 PM
89N10GTA's Avatar
Car: 1989 GTA
if it was the o2 then the light should be on all the time the car is in closed loop.
Old Jul 16, 2007 | 03:46 PM
Cragar87's Avatar
Well, that rules out that theory. I am going to have to do some looking at the fuel system as that is what I keep hearing about.
Old Jul 16, 2007 | 04:03 PM
89N10GTA's Avatar
Car: 1989 GTA
yeah check that fuel pressure and the dis. before spending any money.
Old Jul 16, 2007 | 06:19 PM
Cragar87's Avatar
Could it be the ECM going bad? I checked my TPS and it looked fine, but that's not a very good way to see if it's still in working order.
I got it up to 4000 RPM while in park at a gradual pace, but if I step on it hard the RPM's drop way down and it almost dies. Any and all ideas are appreciated because this is causing me to pull out my hair.
Old Jul 17, 2007 | 07:09 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Check the code that SES set. It'll still be stored in the ECM.
Old Jul 17, 2007 | 08:14 AM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Check for lowfuel pressure/low volume or an exhaust restriction (cat convertor)
BRoss99
Aug 10, 2025 05:08 PM
camaro11j
Sep 19, 2018 08:49 AM
justin57
Aug 20, 2015 07:05 PM
cstrobel65
Aug 15, 2015 10:19 AM
Elliswon
Aug 10, 2015 12:33 PM
