Gas pedal came off!
Old Jul 17, 2007 | 03:08 PM
Lucid's Avatar
Car: 86 Camaro Z28/ 87 Camaro IROC Z28
Engine: 5.0L TPI LB9 / 5.0 TPI LB9 w/cam
Transmission: Built 700R4 with Transgo shift kit
Axle/Gears: 3.27 9 bolt Posi/ 2.73 10 bolt Posi
Gas pedal came off!
I was driving my dads 5 speed today and the gas pedal fell off and got lodged underneath the pedal!! I drove it home pressing down on the pointed end of the metal shaft. I didnt know which board to post this in...
There seems to be a pin that goes through the plastic pedal/spring and through the metal shaft as well. I tried to reattach it but it fell off again. Is there a clip or something that retains it in place?
Old Jul 18, 2007 | 05:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's been a long time since I've looked at that piece. Perhaps someone who has more recent exposure could respond.
Old Jul 18, 2007 | 07:17 PM
Lucid's Avatar
Re: Gas pedal came off!
it looks like there is a spring that hooks onto the pedal stem and and against the plastic pedal. a roll pin goes through the holes in the pedal and stem and the coils in the spring. the holes are plastic and they look worn. time for new parts
Old Jul 18, 2007 | 07:30 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
for a quick fix ,take a small bolt and tap ,stick bolt thru first hole,thru metal rod ,thru other hole put tap on ,tighten enuf to hold pedal in position until you can fix it ,worked great for my son.later jimmy
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
camaro1185
Oct 26, 2015 06:51 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
