serpentine belt+ 8"dampner...
Old Jul 19, 2007 | 11:16 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
okay i have given up searching through all the will a 305 fit on a 350...
now i have a 350 with the 8" dampner what i need to know is will it have clearance issues with the serpintine brackets off of my RS
if so is it anything a little grinding wont cure?
and will my crank pulley from the 305 be the right distance off of the 8" dampner...
Old Jul 21, 2007 | 07:03 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: serpentine belt+ 8"dampner...
The distance to the face of all dampers should be the same. The only problem I ran into putting an 8" damper on my '88 serpentine setup is clearance with the metal coolant tubes that go to the oil cooler. Very, very close to the 8" damper ring (less than .010"). I don't know if your setup uses this or not. If you have a timing cover that matches the 8" balancer you should be fine. Sorry for the crappy picture, everything is painted black.
Old Jul 21, 2007 | 08:56 PM
Car: 91 RS
Engine: 350 vortec
that is perfect... dont have an oil cooler... this engine has battled me all the way... finely i win a round
Galaxie500XL
Feb 1, 2020 04:53 AM
evilstuie
Jan 9, 2020 08:29 PM
jrdturbo
Mar 31, 2016 02:58 PM
codeysabatini
Nov 10, 2015 04:07 PM
evilstuie
Sep 24, 2015 02:31 AM
