How do you switch from serpentine to v-belt?
Subscribe
Jul 21, 2007 | 12:38 AM
How do you switch from a serpentine to v-belt on a 91 camaro? What would i need?
Reply 0
Jul 21, 2007 | 12:43 AM
Re: How do you switch from serpentine to v-belt?
Why switch??
Reply 0
All v-belt brackets and accesories.
edit: and a new water pump.
Reply 0
Jul 21, 2007 | 05:42 AM
Quote: Why switch??
I'm curious too. Most people want to go from V-belt TO serp.
JamesC
Reply 0
Jul 21, 2007 | 07:21 AM
Maybe cause its easier to run a setup like alternator/waterpump or alternator/waterpump/ps pump and no AC or air pump. Unlike the serp setup where you have to run delete pulleys to keep the tensioner, its just brackets on the passenger side of the motor and takes up space/weight/cluster.
V belt the alternator could go to either side to kinda "balance" the look.
I considered it but i doubt id do it.
Just curious could i use the same alternator/ps pump and just swap pulleys?
Reply 0
Jul 21, 2007 | 01:52 PM
Yes you can swap pullies (i couldent use a newer power steering pump with my aftermarket bracket tho), have to get a new water pump also. The serp water pumps turn backwards.
Reply 0
Jul 21, 2007 | 03:56 PM
I want to switch because i i want to run an electric water pump and delete the ac delete and smog pump delete,
Reply 0
Jul 21, 2007 | 09:00 PM
couldnt you do that with the serp set up and just remove the AC/ smog pulleys... seems like it would be easy
Reply 0
Jul 22, 2007 | 02:12 AM
Quote: couldnt you do that with the serp set up and just remove the AC/ smog pulleys... seems like it would be easy
No because the belt tensioner would not be useable which is needed by the serp set up
Reply 0
Subscribe
