Trouble with intake bolts (Weiand intake)
Old Jul 22, 2007 | 09:17 PM
the phoenix's Avatar
Car: 1985 Pontiac Trans Am - PROJECT
Engine: 412 c.i. SBC / 6.75 L
Axle/Gears: Borg Warner 3.27
Ok, I have a pretty simple, but frustrating problem. I can't get to the middle two intake bolts because of the curvature of the intake itself. I've tried both open-end and box wrenches, sockets, swivels, etc...
Has anyone had a high rise single plane intake and what did you use to tighten/loosen the bolts? Thanks in advance...
Old Jul 22, 2007 | 09:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
1" long header bolts. The 7/16" head makes getting a wrench on much easier.
Old Jul 23, 2007 | 08:51 PM
Re: Trouble with intake bolts (Weiand intake)
I'm sorry. I don't think I was detailed enough...
The intake is ON the car. I'm trying to get it off due to height restrictions with the hood. I'm trying to swap this high rise intake for a regular performer...
I'm just trying to get these bolts out...
Old Jul 23, 2007 | 08:53 PM
BTDT.
9/16" - 5/8" box end wrench, with the 9/16" end ground down so it will clear the obstructions.
And alot of patience.... 1/12 turn at a time.
Old Jul 23, 2007 | 11:09 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
BTDT ?
Another option when putting it back on is to use allen head bolts. That's what i've got, and an allen key is quite easy to get in there.
Old Jul 24, 2007 | 06:46 AM
BTDT
Been There Done That. (Got the T-shirt)
evilstuie
Apr 14, 2016 08:52 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
