weak spark any ideas?
Old Jul 24, 2007 | 01:48 PM
TAtothefloor's Avatar
my problem is weak spark and ive been trying to narrow it down for about a week now. i have all new- accel cap and rotor, 8mm wires, platinimum plugs with .035 gap, and a new pick up coil and a durlalast battery that has more cranking amps then required
I have tried 2 coils a msd and stock, the stock was tested and its good so was the ignition module and that checked out fine when i replaced the pick up coil it was all corded and rusted in the distributor but i cleaned it out and its much better now also the coil is grounded and i used a test light to check for power to it and its good i did not check the distributor connections yet but will do so
any ideas to what my problem might be?
thanks in advance
Old Jul 24, 2007 | 09:59 PM
JB22's Avatar
Re: weak spark any ideas?
check and make sure you dont have any vacuum leaks. I thought I was having weak spark problems, but I had a vacuum leak.
food for thought.
Street Lethal
Apr 30, 2019 12:14 PM
Justin69
Aug 31, 2015 11:31 AM
Thaney9
Aug 29, 2015 03:16 PM
justin57
Aug 20, 2015 07:05 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
