Got into an accident...
Old Jul 24, 2007 | 03:20 PM
Gangstajpimpin's Avatar
Car: 25th Anniversary Camaro RS (1992)
Engine: 3.1 V6
I recently got into an accident and here is what happened.
I have an automatic v6 camaro
When i shift it says its in reverse when really its in park and it says its in overdrive when its in neutral and so on...
how do i fix this?
thank you
Old Jul 24, 2007 | 04:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Got into an accident...
check the linkage on the trans oil pan, if its loose it can cause this. if that is not the case, there is a way to adjust the cable but i dont know how off the top of my head
Old Jul 25, 2007 | 07:03 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Adjustment is just loosening the nut at the shift lever on the case.
Make sure your cable is seated firmly in the bracket that 86 is talking about.
Old Jul 25, 2007 | 11:29 AM
Engine: 3.1 V6
ok, i will check that...
and also
is that bumper material required? where can i get it? That is LT4Hawks car
Old Jul 25, 2007 | 08:13 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the honey comb stuff? its impact absorber, if you drive on the street its a good idea to have it, junkyard+cheap, Classic Industries
#G3823 for 85-90, about 150 plus shipping
#G3828 for 91-92, about 170 plus shipping
Old Jul 27, 2007 | 01:35 AM
Engine: 3.1 V6
this might make me sound like the most un-observant newbie out there, but how do you remove the front bumper? what kind of bits do i have to use for removal? It appeared to be a square bit, but im not sure. your help is appreciated!! thanks
plasmeh
Apr 15, 2009 07:38 AM
tpi-hearse
Nov 14, 2006 11:09 AM
Stingraye
Jul 24, 2003 11:25 PM
GarageToys
Classified Ads Feedback Board
Feb 14, 2003 01:36 PM
383 Smoka
Jan 20, 2003 02:05 AM
