Just Got The New, Genuine Delco AC Compressor.
Old Jul 25, 2007 | 12:51 PM
NoTransistors's Avatar
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
I hope that enough of it was made HERE to warrant all that searching for a unit not made in China.
Anyway, the instructions say to use either mineral oil [for R-12], or PAG [for R-134A]. No mention of Ester Oil.
My system is full of Ester Oil, as it is compatible with all known refrigerants, even the organic ones.
Is it OK, in your opinions, to put in those two ounces of Ester oil, and go ahead with the installation? I will be using R-134A, but if I find that extra one pound of wonderful R-12 in the future, I will then have the three necessary to refill it with the real stuff.
Thank You,
Seth
Old Jul 25, 2007 | 07:05 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Re: Just Got The New, Genuine Delco AC Compressor.
Do you have the equipment to fill R12? If not i woud just fill the system with R-134a.
Also are you replacing the accumulator and the orffice tube, along with vaccuming down the system? These steps are very important to the life of the new compressor.
Old Jul 25, 2007 | 07:47 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by NoTransistors
... I will be using R-134A, but if I find that extra one pound of wonderful R-12 in the future, I will then have the three necessary to refill it with the real stuff.
Thank You,
Seth
Do you need one can or one pound of R-12?
Old Jul 25, 2007 | 08:38 PM
I seem to be one pound short.
If I had gone to the Hamfest in N.J. last week, I certainly would have secured the R-12. In the recent past, I have gotten this stuff at these Hamfests for $15/container.
As a new or rebuilt compressor needs to bed in, I will be leaking a bit for the first week after installation, so I am best off initially with R-134A. Then I can switch to something else. I was very happy with Envirosafe, as it works at very low pressures, and does not react with moisture.
I have secured a new receiver/dryer and a variable orifice valve. A 'V.O.V.' seems better suited for the higher-pressure R-134A.
I guess I need to borrow a vacuum pump. A long time ago, when a can of R-12 was cheaper than a can of Pepsi, I would simply chase the air out of the system with an entire can of freon. Always seemed to do the job, as, at least in the case of the home-made A.C. system in my Triumph TR-7, the system would get so cold, that the car could double as a beer cooler.
BTW, I have the manifold gauge set, for what its worth.
Seth
Old Jul 28, 2007 | 12:16 AM
Any Ideas On This Odd Issue?
It is up and running with R-134A. The V.O.V. is an interesting addition, that I might need to remove.
It seems to restrict cooling performance to 60 degree vent temp, until under-hood heat soaks the system a bit, building more head pressure in the compressor. Then it magically gives a 45 degree vent temp. The valve is the only explanation for this wierd happening, as I would normally expect an opposite problem. A dirt clog might be an all-the-time issue.
As a matter of fact, the low pressure side seems to stay at 25 pounds and high at 250, warmed up, with hood opened, even when I fill it up with an extra ouce or so. Pressures change and then equalize back to these readings. Guess the valve is opening under higher pressure, to improve cooling and reduce pressure.
Also, cycle switch is set to 23 lbs, and works as needed until warmed up, rarely cycling after that.
Is the V.O.V. supposed to work like this?
And is a fixed unit better? It is obviously more reliable.
Thoughts?
Seth
Old Jul 28, 2007 | 10:17 PM
I hate to push, but if I knew the answer, I would not have asked.
Also, were the heck can I get the rebuild kit for the windshield washer pump? It is integrated into the wiper motor assembly, and it seems that the local chains have given up selling this once-common item.
Seth
Old Jul 29, 2007 | 08:47 AM
Engine: 350 4BBL
You mean this KIT?
Auto Zone sells the whole pump too.
Veaceonee
Sep 29, 2016 08:15 PM
Reid Fleming
Oct 10, 2015 09:56 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
BLK87Z
Sep 18, 2015 11:29 PM
rsrookie
Sep 5, 2015 07:08 PM
