Roller Cams
Old Jul 25, 2007 | 05:31 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Roller Cams
Ok i am looking to build a motor using the same specs as a 383 built in Chevy HI-PO. they use a Roller cam and lifters but they have a new block. my question is can i use the same cam and lifters. cam number is 12-419-8 and lifters are 850-16. i have a pre 87 block so this why i am confused. will it work?
Old Jul 25, 2007 | 07:48 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: Roller Cams
You can use a roller cam and lifters in your block but you will need different lifters. You will need to get some retrofit roller lifters, they are more expensive. Heres a good article that explains everything you need to do.
http://www.chevyhiperformance.com/te...cam/index.html
Old Jul 25, 2007 | 08:12 PM
Re: Roller Cams
You can use that cam, but not those lifters. Those are the factory roller type lifters for 87-up blocks.
You need part # 853-16 lifters instead.
You'll also need a cam button and a stiffer timing cover than your stock one; or, a timing cover with a built-in cam button, like this one.
Old Jul 27, 2007 | 02:29 PM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
Re: Roller Cams
Ok now the new question. Is there a NON- Roller cam that i can use that has the same profile as that one. I ahve been looking but can't seem to find a cam that is close to the same specs? any one help me?
Old Jul 27, 2007 | 03:13 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Roller Cams
You won't find a non-roller cam with the exact same profiles. The flat tappet cam needs to have longer, gentler ramps than the roller.
Old Jul 27, 2007 | 06:31 PM
Re: Roller Cams
Sticker shock?
Do you want to build the motor, or not??
You DO of course realize that there's a REASON they used a roller cam. Right?
Speed costs money. How fast are you willing to spend?
Old Jul 30, 2007 | 08:45 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Re: Roller Cams
Ya, roller cams reduces A LOT of resistance freeing up that horse power.
Old Jul 30, 2007 | 10:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Roller Cams
The advantage of the roller cam isn't from reduced friction (although it's nice that it's almost impossible to wipe them out), it's from the more aggressive profiles that are possible compared to the flat tappet.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
