engine problem HELP!!!!!!!
Old Jul 28, 2007 | 05:25 PM
transam360's Avatar
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
ok first off i will list what is done to the engine i have a 350 sbc that is bored .060 over it has been decked the cam is a 510 int. 533 exh lift with a 244 int./254 exh. at .050" . Pistons are eagle flat top pistons with eagle rods and crank the heads are ported vortec heads and has a high rise airgap intake single plane the carb is a edlbrooke 600cfm carb... also has long tube headers with dual exhast and th350 trans 4:11 gears and 3000 stall.
So ok heres my problem when the engine is idleing it runs great sounds good to but as soon as i put it in gear the idle goes down to like 400 rpm and will almost die i have a 3000 stall and when i took it around the block it had almost no power at all what is going on I NEED HELP THANKS ERIC
Old Jul 28, 2007 | 06:02 PM
Re: engine problem HELP!!!!!!!
Too much cam, not enough motor, wrong carb.
Those cheeepie generic cams typically cause ALOT of trouble like this. Even when purchased in an Edelbrock box (which I hope you didn't.... that's the most expensive way to buy them). Besides not really running as good as modern ones; anything designed in, say, the last 40 years or so.
Try a Comp XE274 instead.
May also be installed wrong; a tooth retarded.
Check your ignition timing as well, BE SURE that you know FOR CERTAIN where TDC REALLY is. The blinky light is pretty much useless when the mark and TDC don't line up. For that matter, have you tried just advancing the distributor and seeing what happens?
Old Jul 28, 2007 | 08:00 PM
transam360's Avatar
the timming marks are lined up and yes i tryed moving the distributer and it dident realy help and also what carb should i have
also i have a new cam layin around it is a .488 .488 lift cam would that be better
Last edited by transam360; Jul 28, 2007 at 08:02 PM. Reason: Automerged Doublepost
Old Jul 28, 2007 | 09:49 PM
Not really.
Same thing, just a smaller one. The next lobe down from the .510" one.
It would be "better" though, or at least "not as bad", in that it is a little closer to something you could run in a 350 without having to wind it up to 6000 RPM before it started making power. It'd only have to go to 4500 or so. Still a super crappy cam, though.
Old Jul 28, 2007 | 09:54 PM
transam360's Avatar
what size carb should i be using
Old Jul 30, 2007 | 08:32 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Buy a timing light. Put the weird clampy thing on your #1 plug wire and hook the red clamp on battery positive and the black clamp on battery negative. Disconnect the computer connector from the back of the distributer. Point the gun at your harmonic balancer and the scale on the timing cover. Sometimes its helpful to fill in the groove on the balancer with a bright paint. From there, every time the light blinks, #1 is firing. So when it blinks you see that groove in the balancer lined up with a value on the scale. This is actual timing. Now slowly turn the distributer and the mark changes its position. Research your base timing using the search button, I cant remember if you set it to 0 or 10 or in between that.
Okay, borrow a friggin timing light then chief. Good luck mate.
Old Jul 30, 2007 | 10:39 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i am running the XE274 in my new 350 vortec with flat tops... and it is pretty mean for the price...and seems to be streetable even with 3.08 gears and stock manifolds...my long tubes didnt fit and i didnt have the patience after fighting it for 3 days by my self... but i like it once i get enough gas off idle it should be great
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
