locktight stick on intake bolts?
Old Jul 25, 2007 | 10:03 PM
82 recarooo's Avatar
has anyone used the blue locktight stick, not the tube, to seal the bolts for intakes? just wondering? would that stuff seal oil and hold the bolts in place?
Old Jul 25, 2007 | 10:27 PM
Freakazooid52's Avatar
Car: 1986 firebird
Transmission: THM350
Re: locktight stick on intake bolts?
dont see why you would put locktite on intake bolts or any sealer, never have and nothing leaked for me.
If I was to put anything on the intake bolts it would be teflon tape or liquid teflon sealer.
that medium strength loctite is useless, you only need the red stuff for flywheel/flexplate bolts, screw in rocker studs, and other bolts that once there in their spot they wont ever need to be taken out.
properly torqued bolts shouldnt loosen
Old Jul 25, 2007 | 11:40 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Liquid Teflon sealer only.
Old Jul 26, 2007 | 05:07 PM
thanks for the answeres. ill go with the teflon sealer
Terrell351
Jun 13, 2021 01:13 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
camaro71633
Sep 1, 2015 10:24 AM
theurge
Aug 21, 2015 12:46 PM
