timing
Old Jul 26, 2007 | 03:52 PM
thirdgenlover's Avatar
Car: 87 trans am
Engine: 350 TPI bored .040 over
Transmission: modified 700r4
Axle/Gears: stock spline, 3.73 Eaton posi
timing
I just recently tuned my car at school on a dyno for fuel, now im going to tune it for timing. I dont have a vacuum advance, but there is some connector to unplug right? Never done this before on my car so i dont even know where this connector is at, and if there is anything else i have to do to set it.
Old Aug 5, 2007 | 01:57 AM
KCGTA's Avatar
Car: 1989 GTA
Engine: 5.7 L L98
Axle/Gears: 2.77
Re: timing
There is a connector to disable the ESC located on the passenger side of the engine compartment near the firewall. It is a single wire connector that is tan with a black stripe. I think your car is old enough, you can disable the computer advance by simply jumping the ALDL terminal at the a and b, in diagnostic mode AFTER you start the engine. Check your label underhood, auto trannys of this vintage require you to set base timing in drive.
Old Aug 5, 2007 | 10:18 PM
Car: 87 trans am
Re: timing
this is to due with the oil leak issue that i had. My question is, has anyone ever had an oil filter go bad on them, as in the seal!
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
