New Engine Problem
Old Jul 29, 2007 | 10:27 PM
kuulkatdadieo's Avatar
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
New Engine Problem
As the title reads, I got a rebuilt engine put in and I got a problem. It's a TPI 350, just like what was in it. It idles great no problem there, but when you give it a little bit of gas to take off, it lowers the rpms about a 100 rpm and then your reaction is to give it more gas and then it is fine. Cruises fine and everything, after that. I don't think it would die but acts like it wants to. In takers to solve my problem. THANKS
Old Jul 29, 2007 | 11:12 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
Re: New Engine Problem
maybe running a little rich and it bogs down? also check your timing.
Old Jul 30, 2007 | 06:05 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
what cam are you running? what stall?
Old Jul 30, 2007 | 01:39 PM
As far as I know it's a stock cam and a stock converter.
What would exactly make it run rich, and I will have my local mechanic check the timing this week.
Last edited by kuulkatdadieo; Jul 30, 2007 at 01:40 PM. Reason: Automerged Doublepost
Old Jul 30, 2007 | 02:19 PM
check the fpr if it is adjustable, o2 sensor.
Old Jul 30, 2007 | 09:12 PM
Thanks,
Yea I'am dropping it off at the mechanic and he said exactly what you said. That it might be the O2 sensor or the fuel system. Thanks again and I'll give you guys the results after tomorrow.
Old Jul 31, 2007 | 12:09 AM
yeah let us know what it was.
Old Aug 1, 2007 | 08:21 PM
Well, it turned out to be the TPS sensor. I told him to go ahead and put it in, because I know those things are real touchy. But, yea the problem is totally fixed and will lay rubber like nobody's business. I'am very glad to see the full potential of my new engine and can't wait to drive it some more. Thanks guys, especially 91 camaro racer, I appreciate it. THANKS
Old Aug 1, 2007 | 09:07 PM
no problem man we are here to help others like you.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
zeitghaist
Aug 18, 2015 07:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
