sea foam on a tpi
Old Jul 31, 2007 | 02:31 PM
blue_iroc_z28's Avatar
Car: 1987 pontiac trans am gta
Transmission: 5 speed
Axle/Gears: 3.43 posi
sea foam on a tpi
whats the best way to get sea foam in to my upper engine on a tpi car?
Old Jul 31, 2007 | 02:52 PM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: sea foam on a tpi
i always go through the pcv hose. it's most likely going to want to stall but if you can get it in there it works great.
Old Jul 31, 2007 | 03:32 PM
how much of a can should i put in ? my car is pretty neglected from other owners
Old Jul 31, 2007 | 03:41 PM
89N10GTA's Avatar
Car: 1989 GTA
what i do is pour it in the hose till it stalls out. after it stalls wait about 2 minutes then start it up and let it smoke out the street. it won't take much at all to stall the car so if you want to keep doing it untill the can is gone i guess you can. make sure it's done smoking before you try again it won't hurt it. it will smoke like hell so make sure you're not indoors or near open windows.
Old Jul 31, 2007 | 04:31 PM
ok ill do that , thanks
Old Aug 1, 2007 | 07:33 AM
84noname's Avatar
remove the brake booster hose pour one third of the can slowly into it while runnin shut it off let it set 5 minutes start it and watch the smoke show do this till u get no smoke show and ur engine is clean. seafoam is the the only thing worth using
Old Jun 7, 2011 | 01:59 PM
R/T-Z28's Avatar
I've never seafoamed this car. Is it the PVC hose connected to the passenger side Valve cover and lead into a port right behind the throttle body.
Old Jun 7, 2011 | 02:53 PM
rdhanded2's Avatar
Top Answer: 1
Car: 91 TA / 91 Formula
Just pull the hose off the brake booster. Super easy. I poor it into a cup and let the vacuum suck it out.
Old Jun 8, 2011 | 04:20 PM
Fermin91rs305's Avatar
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
i know this might be another post but i need some advice. My mechanic and I are doing a head gasket swap after mine blew up and now my whole engine has oil with antifreeze on it. I am going to be switching the oil on it before i start it up. My question is Sea Foam is know to clean all your internals and that would be great to take away all the extra antifreeze after i change the oil because i want it to be like new. If there is another specific cleaner for that please let me know thanks
Old Jun 8, 2011 | 04:29 PM
HawkZ28's Avatar
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Seafoam or MMO should be fine. Run some Rotella oil with seafoam through, bring it to operating temp, drain, change the filter, and fill with whatever you usually use. Basically you're doing a motor flush. BG has a product by that name, too- pretty nasty stuff from what I've heard.
You're bearings were ok?
https://www.thirdgen.org/forums/afte...oduct-but.html
Old Jun 8, 2011 | 04:45 PM
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Okay thanks sounds like what ima be doing because my car is my baby and needs to be good. And about the bearing I hope so but mechanic said they are good. I was headed home and i gunned it from 0-45mph and then turned turned off my car and when i went to start it thats when you heard it happen. So i drove it to my mechanic and after that i has not moved at all it was towed and all that but when it did turn on there was no noise and good idle
stalkier
Dec 6, 2015 11:25 PM
777Shock777
Oct 29, 2015 04:30 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
