Starter Help
Old Aug 1, 2007 | 01:12 AM
85S10projectz28's Avatar
Car: 91RS, 90 K5 Blazer
Engine: 91 355 TBI
Transmission: 91 700r4 with shift kit
Starter Help
Ok here is my problem. I have a 350 from I dont know what with a Turbo 350 tranny. The motor is mildly built and my stock starter has decided to break off of my block. I have drilled out the one bolt and retaped both holes, but now every time I try to start it grinds. If I stick a socket in between my starter and oil pan it cathes the flexplate just fine (most of the time) but once it starts the socket falls out and the starter will not recrank but instead will grind. I have heard of braces that used to be used and wondered if that might help? Also could I use a inline mini starter instead of the staggered bolts? Any help would be nice as I want to be able to drive it again.
Old Aug 1, 2007 | 01:18 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Starter Help
It sounds like the alignment of the bolt holes has been messed up with drilling and retapping.
Old Aug 1, 2007 | 01:19 AM
Engine: 91 355 TBI
Re: Starter Help
well my bolck is setup for inline and staggered. I want to put an inline but from what I have read you cant do it with out switching flexplates.
Old Aug 4, 2007 | 09:51 PM
Engine: 91 355 TBI
Re: Starter Help
any other ideas?
Old Aug 5, 2007 | 04:20 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Starter Help
What's wrong with changing the flexplate?
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
