retarding and advancing
Old Aug 1, 2007 | 05:25 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I have my car retarded right now for nitrous. i dont plan on running nitrous every time i race, so I wanted to advance the timing until i buy a msd ignition to auto retard my car. My question is will I see much of a gain in power or throttle repsonse from a far retard to an advance timing?
Old Aug 1, 2007 | 05:45 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: retarding and advancing
Yeah you should. I remember last summer I retarded the motor from 12 degrees at idle to right around 4-6 so I could run a lower grade gas and I could feel the difference. I said 'screw that, the extra 20 cents is worth it' and put it back to 12. I would say if you took it from -X to 10-12 you'd see a decent gain. Remember, 6 is factory.
Fanatic1074
Oct 3, 2022 05:57 AM
djmarch
Oct 2, 2015 10:41 PM
Bigold4x4
Sep 28, 2015 05:21 PM
Damon
Sep 26, 2015 04:29 PM
