electric fans on my car???
Old Aug 1, 2007 | 11:38 PM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
should my 87 iroc have 2 electric fans or one? i was looking at it today and noticed it had two, also is the radiator aluminum? how about the driveshaft?
Old Aug 1, 2007 | 11:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: electric fans on my car???
It has two fans if you have A/C, one if you don't. The radiator is aluminum. The driveshaft is aluminum if you have the JG1 option, steel if you don't.
Old Aug 2, 2007 | 12:03 AM
Engine: 2002 Ls1
Transmission: t-56
yes, it has a/c how can i tell if it has the jg1 option without crawling under the car and sticking a magnet to it? does anyone know what my gear ratio is? its an auto, tpi 305, 9 bolt with discs, and what are the baffles ppl are talking about on the gas tank? could mine have it?
Old Aug 2, 2007 | 12:21 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could find the RPO list for the car and see if JG1 appears on it, or just look underneath the car at the shaft. If it has rust on it, it's not aluminum.
The baffled gas tank thing is just an urban legend, don't worry about it.
Old Aug 2, 2007 | 08:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, the JG1 shaft didn't make an appearance until 1988.
JamesC
Old Aug 2, 2007 | 12:45 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
The RPOs are on the underside of the console lid.
Old Aug 4, 2007 | 12:53 AM
kdxrider9262's Avatar
Car: 1987 IROC-Z Camaro
is there a way or any reason to manually hookup the other electric fan? I removed the ac cause it didnt work anymore and didnt want to convert to 134a? I figured the car might run a lil cooler?
RazorN8
Jan 7, 2022 11:44 AM
86IROC112
Aug 17, 2015 02:00 PM
mizz0313
Aug 12, 2015 06:45 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
