Sould I re-torque my heads?
Old Aug 3, 2007 | 10:05 PM
327???'s Avatar
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
The engine has about 1000mi on it and 15-20 passes, should I re-torque my heads or are they ok?
Aluminum heads and felpro gaskets.
Old Aug 3, 2007 | 10:06 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: Sould I re-torque my heads?
Yes, yes and yes
Old Aug 4, 2007 | 12:18 AM
327???'s Avatar
I should do it with the engine cold, correct?
Old Aug 4, 2007 | 07:37 AM
No.
Not necessary. Assuming it was done right the first time, that is.
Old Aug 4, 2007 | 10:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I agree with Sofa.
You should check the paperwork for the heads though. Some suggest re-torquing on high compression or forced induction setups.
Old Aug 4, 2007 | 10:31 AM
Car: 1979 Malibu
Engine: Blown LSx
theres no harm in retourqing the heads
Old Aug 4, 2007 | 11:06 AM
327???'s Avatar
No.
What do you mean by right? I did it in 3 steps from the center out, just like in the book(rebuilding an sbc br david vizard).
They're trickflows and it's got 10.5:1 compression.
Old Aug 4, 2007 | 11:42 AM
I mean, if you're confident you did it right, then there's no need to redo it.
Yes there is potential harm. Assuming that the thread sealer doesn't leak now, the seal can be broken and coolant begin leaking into the oil by disturbing the bolts.
FelPro SPECIFICALLY advertises "no re-torque neceesary" for their blue gaskets; has been for near 30 years now. Hence their trade name, "Permatorque".
Old Aug 4, 2007 | 12:57 PM
327???'s Avatar
I don't think I'm gonna mess with it then.
Thanks!
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i run my car hard and have never went back and retorqued my heads.. 10.65:1, 385 spinnin to 6600rpm.. i only had problems when i rebuilt my motor.. i disturbed the bolts like sofa said, broke the seal on the locktite and started a leak..
Old Aug 4, 2007 | 01:05 PM
327???'s Avatar
I used liquid teflon, but I'm not gonna chance it. That and my rockers get in the way of the head bolts and setting them is a pain.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
