how can I get more hp??....
Old Aug 8, 2007 | 05:17 PM
1BadaGTA's Avatar
Car: 1991 Gta trans am
Engine: 383ci,trickflow alum. heads, hsr
Transmission: T-56, alumin. driveshaft
Axle/Gears: stock 7.5"/3.42
I just finished my car's motor I have built a 383 stroker motor all forged interals, had $1200 in block work done to it balancing, decking, bored etc. I put 195cc trickflow heads on it that have a 72cc, flattop pistions, 1.6rr, hardened pushrods, full aftermarket exhuast, shorty headers, hsr intake, cai, high volume oil pump, comp cams 230/236; .570/.576 lift; 113lsa, 30lb injectors, 255 holley fuel pump, msd 6al box, 8.5mm wires, new cap, rotor, msd blaster coil. I have all that backed by a t-56 six speed and 3.73 gears in the 7.5" stock rear. And I can't seem to think of anyway to get more power out of my car. Any suggestions?
Old Aug 8, 2007 | 08:32 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: how can I get more hp??....
Good golly! Set up right, that combo should make close to 450 hp. How much do you need anyway?
Spend a few bucks and dyno it. There may be something way out of whack if it ain't pinning you back in the seat and roasting the tires.
Old Aug 8, 2007 | 08:47 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
I would suggest more compression, with smaller combustion chamber heads. either the 64cc combustion chamber Trick Flow 195cc heads or the 67cc combustion chamber Trick Flow 215cc heads
Old Aug 8, 2007 | 08:59 PM
Nitrous?
Tuning? When you dyno tuned it, how much did you pick up from drive-in to rive-out? What did they do? What's your A/F ratio and ignition curve? Where does it make peak torque and peak power?
What is it putting down now? Kind of pointless to talk about "more" power when you don't tell us what it's currently doing.
As we all know, there's ALOT more to going fast than engine output. I don't notice ANY suspension or other traction mods at all? Maybe it's time to close the hood and take a look at OTHER things that are making the car slow?
Old Aug 9, 2007 | 01:30 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
more compression, more tuning, long tubes, true duals with an x-pipe, ditch the EFI and go portmatched super victor w/ 950HP, solid roller, bigger heads(AFR 210), nitrous
Old Aug 9, 2007 | 01:46 AM
F-Body Demon's Avatar
You got forged internals man, easy money. Boost or N2O
ULTM8Z
Sep 16, 2015 09:15 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
Roshambo
Aug 24, 2001 08:48 PM
CrazyHawaiian
Car Audio
Aug 6, 2001 04:16 PM
IROC315
May 15, 2001 10:34 AM
