Help my car won't start!
Old Aug 9, 2007 | 02:51 PM
snowcougar's Avatar
Hi,
I own a 1991 RS with the 191 v6. Yesterday I was accelerating from a stop light when it started misfiring pretty bad. It proceeded to die and not start at the next full stop.
I have 40PSI at the fuel rail. And what appears to be a white (bluish?) spark from the coil. However there seems to be no spark at any of the plugs. Cap and rotor look perfect but I am going now to get a replacement just in case.
Is this a timing malfunction? Any other ideas would help! I am quite stumped
Old Aug 9, 2007 | 03:39 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
Re: Help my car won't start!
umm if u have no spark it either the (Ignition Module) or the (Coil)
Old Aug 9, 2007 | 04:29 PM
snowcougar's Avatar
I have a strong spark immediately off of the coil. I also swapped the Ignition Module for one that I know is good and the same effect. No Start.
Old Aug 9, 2007 | 06:42 PM
ProjectIrocZ28's Avatar
Car: 88 Monte Carlo
Axle/Gears: Really Tall ones. Probably 2.73's
check fuel pressure specs. that sounds low, but i dont remember the spec.
and make sure you get spark all the way down to the spark plug.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
