Oil pressure switch over ride?
Old Aug 10, 2007 | 08:24 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Hello,
I recently installed all new Autometer gauges and I am using the port for the oil pressure switch for my oil pressure sender. The car will still run without that switch, right? Is there a way I can over ride it or should I not even bother? Thanks in advace.
Andy
Old Aug 10, 2007 | 09:38 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Between the oil pressure gage and oil pressure switch, the switch is the more important of the two.
Either tee the fitting, or use another pressure port for the oil pressure gage.
Old Aug 10, 2007 | 09:42 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Re: Oil pressure switch over ride?
When I searched, I found that the switch isn't a safety feature, it's just a backup to the fuel pump relay. Is that incorrect?
Thanks.
Andy
Old Aug 11, 2007 | 11:52 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That's correct.
Old Aug 12, 2007 | 09:00 AM
Car: 1989 IROC-Z
Engine: 383 stroker
Originally Posted by Apeiron
That's correct.
So... I don't need it or I do need it?
Old Aug 12, 2007 | 03:45 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you ECM and your fuel pump relay are happy, you don't need it. If one of them goes on you, you'll wish you had it.
Old Aug 12, 2007 | 04:20 PM
Car: 1989 IROC-Z
Engine: 383 stroker
Can I wire in a 4 pin relay in place of the switch?
Old Aug 13, 2007 | 12:21 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What would that accomplish?
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
dcbsracing007
Aug 18, 2015 07:24 AM
TA8487
Aug 16, 2015 12:21 PM
