Flex plate is bashing my torque converter!?
Old Aug 11, 2007 | 07:30 PM
79frankenstein's Avatar
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
ok, as above my flex plate is bashing my torque converter when the engine is running and i dont know why. Its a 79 350 with a TH-350 Trans. I did not put the engine or trans in the car so i have no idea whats stock or not. The engine has solid motor mounts and a stock starter. This noise just recently started and the only thing i could think of is a cracked flex plate or maybe the solid mounts vibrated some bolts and nuts loose on the trans or something? ANY IDEAS Please Help?
Old Aug 11, 2007 | 07:57 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Re: Flex plate is bashing my torque converter!?
A cracked flexplate is more common than you may realize. First, check to make sure that all of your bolt/nut sets are nice and tight. If you do have a crack there doesn't have to be a problem other than worn out parts.
Replace it.
Old Aug 12, 2007 | 01:27 PM
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
I now checked the flex plate and there seem to be no cracks. So i tightened all of the screws from the Flex plate to the TC. The flex plate is not flexing very badly anymore however my TC is what seems to be wobbling around now. but when i check the TC when to engine is not running, everything seems tight and in place.... i have no idea whats going on.
Old Aug 12, 2007 | 01:56 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by 79frankenstein
...The flex plate is not flexing very badly anymore however my TC is what seems to be wobbling around now. but when i check the TC when to engine is not running, everything seems tight and in place.... i have no idea whats going on.
Check the bellhousing to engine bolt torque and verify that the upper 2 bolts are actually there.
Some people leave them out because they are hard to get to.
Also when the flexplate cracks, it's around the crankshaft bolts. Very hard (impossible) to see with the trans in place.
I would be suspicious if someone else put the '79 engine in it.
Cracked/broken flex plate sounds like THIS.
Old Aug 12, 2007 | 03:23 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
poor wishmaster... so many problems
Old Aug 12, 2007 | 04:13 PM
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
well im glad to say that it doesn't sound like that. Its more like a knock then a chatter or scrape. I can also see the torque converter kinda wobble into the flex plate and knock.
Old Aug 12, 2007 | 04:21 PM
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
ill post a video of it tomorrow for some more help
Old Aug 12, 2007 | 05:58 PM
Car: 86 z28
Engine: 350 sbc
Transmission: TH350
http://www.youtube.com/watch?v=C686kk29j0I
morrow
Jan 13, 2024 12:29 PM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
andy74
Sep 3, 2015 08:41 AM
tonys91rs
Sep 2, 2015 07:07 PM
