synthetic oil ok to use in a rebuild engine
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
ok i bought pennzoil synthetic oil before i rebuild the engine,will it be ok to use
Car: 1988 IROC-Z
Re: synthetic oil ok to use in a rebuild engine
ohh ok just was wondering,read on pennzoil said that use regualer oil to make sure everything break in ok like piston rings and stuff..just had me worried there,tomorrow will be the day it will fire up again and i hope it dont knock if it does im going to blown that m-fer up..well maybe not cause i love it to much lol
Transmission: 4L80E/4L80E
The main thing that needs "breaking in" is cam & lifters with flat-tappets. Rollers no problem.
Can't say I have a lot of respect for the brand, but probably best to use petroleum-based oil for the initial run, drain it, put petroleum-based back in for a few hundred miles, then switch to synthetic.
Car: 89 IROC
Engine: 6.8 HSR N2O
Transmission: TKO 600
Axle/Gears: 9" Moser 3.50 True trac
Im really on the fence on this one. I've built dozens of engines and never had a problem. Til the last one. I put a full synthetic in for the start up. This motor has used oil since day one. Fouls plugs on 2 5 & 7. The machine shop said it was probably due to the synthetic during break in. I don't really see it but I'm tearing the motor down this week after only 25k. I'll know if something else is wrong then. I'm planning NOT to use synthetic this time. Maybe just and "old mechanics tale" but why take the chance. Besides, I plan on changing the breaking oil after only a few hundred miles so the added cost isn't worth it. Just one man's opinion...
Car: 1988 IROC-Z
umm well i guess i have to take my chances now since i already pour it in
Car: 1988 IROC-Z
yeah and probably spill have off it..but i dont see how synthetic oil will do any harm.
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Mobil says on their site that synthetic is OK for for engine break-in. They have a list of cars that roll out of the factory with synthetic oil in the crankcase.
http://www.mobiloil.com/USA-English/...ics/Myths.aspx
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
It's a source of debate.
Personally I use 30W dino juice for break-in.
If I was you, I'd check with the ring manufacturer and see what they recomend. Total Seal says they don't recommend synthetic for break-in. Other mfgs may agree or not. Why take the chance? Dino oil won't hurt anything and its got to be changed soon anyway. All the synthetic oil companys say it doesn't hurt to change from dino to synthetic.
Car: 1988 IROC-Z
well i drain it with no spills probably wont never happen again lol..so im going to go to autozone a get some cheap oil then put the synthetic in after 300miles or so..
better be safe then sorry
Go for mineral oil, Some might say syntetic is ok for brake inn but no one tells you stay away from mineral oil! And dont go for the cheapest one, you get what you pay for.
Car: 1990 RS
Engine: Mild 396 Smallblock
Transmission: TCI Streetfighter turbo 350
Axle/Gears: 3.73 10 bolt Strange Posi
NO! I'm glad you drained it, your rings will never seat if you startup with synthetic!
Car: 89 IROC
Engine: 6.8 HSR N2O
Just a follow up to my earlier post. I used synthetic oil during break in and this motor used a quart every 800 miles or so from day 1. I disassembled my engine the other night and there are no signs of any problems except that the rings just didn't seat. The cross hatch from honing is still there after 24K miles! It's odd too that the rings aren't shiny on the face like you'd normally find on used rings. The worst part is that I really knew better... but I reasoned that since there are engines shipped from the factory with synthetic so it should be ok- right? If it's good enough for a Corvette it's good enough for my IROC! Well I can't say for sure that the synthetic oil kept my rings from seating but I've never had this problem before. I will never again use synthetic during break in. But I probably will after about 1k miles so I can use a low weight oil (5-30w) to reduce the oiling system's parasitic drag. (almost free HP!) If synthetic DID cause the rings not to seat then this proves how good synthetic is when it comes to lubrication. It's just too slick for break in. Kinda makes me wonder what GM does to make it work for the Vette.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
