engine stalls after warming up
Old Aug 13, 2007 | 09:36 AM
hot92RS's Avatar
Car: 92 Z-28
Transmission: THM700R4
Any help appreciated. My Z-28 305 TPI Auto runs strong when running for about 10-15 minutes. When stopping for a light, it will stall, cranks right back up but will not idle. Any suggestions as to where I should look first?
Old Aug 13, 2007 | 12:35 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: engine stalls after warming up
I would check the IAC sensor and see if its full of carbon.
Hope this helps.
Old Aug 13, 2007 | 05:56 PM
hot92RS's Avatar
Car: 92 Z-28
thanx, I will do that. if it is, what should I clean it with or do I just replace it?
Old Aug 13, 2007 | 06:03 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
mine is doing the same thing...will run as long as im on the gas. stalls at every stop sign and light.
i haven't done a tune up on this car yet...got all the stuff and im gonna see if thats the problem. i'll get back to you
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
Jake_92RS
Aug 17, 2015 09:42 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
