lt1 cam question
Old Aug 15, 2007 | 08:26 PM
gt500pwr's Avatar
lt1 cam question
I just received a cam from Ebay, guy selling said it was from 93-95 vette. When I received it I measured the lobes and sure enough looks like 450/460, which would indicate 93-95 vette. The question is though, there's a lobe that looks just like a circle where the fp lobe would be based on the info from the lt1 digest in the tbi section. Also, the cam shaft and lobes aren't smooth, they've got like flat spots all the way around. Is that normal or has this seen just too much wear?
Old Aug 15, 2007 | 09:07 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: lt1 cam question
Pics?
Old Aug 15, 2007 | 09:09 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
well that lobe that looks like a circle is the FP lobe i believe it is called a concentric... as for flat spots... either more discription on locations, size or a pic to be sure
Old Aug 19, 2007 | 08:22 PM
gt500pwr's Avatar
Here are a couple of images of the camshaft. You can see that the journals are not smooth around, this is consistent with the entire camshaft. The lobe which should be the FP lobe is just round, not concentric?
Attached Thumbnails lt1 cam question-img_4158.jpg   lt1 cam question-img_4156.jpg
Old Aug 21, 2007 | 06:11 PM
gt500pwr's Avatar
Anybody?
Old Aug 21, 2007 | 07:13 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
There should be at least three numbers stamped on one end or the other. Can you find them, and what are they?
Maybe something like 142?
Ron
Old Aug 21, 2007 | 08:07 PM
I can't tell much from the pics.
The first one is of the back end of the cam... useless.
The second one has the front bearing journal in focus, but the FP eccentric (the first "feature" behind the bearing journal) is not. Also useless.
Take a pic of the cam where we can compare the center of the eccentric to the center of the front bearing journal. Like, note in this pic, how far different the eccentric's center is from the brg journal's center (it's "offset").
Old Aug 21, 2007 | 09:30 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Man i don't think I would run that cam.... I think some of those lobes look pretty rough. Maybe take it by your local regrinding shop and get an estimate for cleaning it up.
Old Aug 22, 2007 | 07:25 AM
gt, you should invest in some image editing software.
After minor manipulation of the image to render it viewable, yes you are right, there is no fuel pump eccentric. Where the eccentric should be, it's ground WAY down too far, and has that same rough finish that the spaces in between lobes all have.
You'll need to run an electric one or something.
The lobes all look fine to me. Nice and shiny where the lifter roller runs on them.
Old Aug 22, 2007 | 07:35 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
IIRC my brand new comp cams cam had flat spots that looked like that.
Old Aug 22, 2007 | 08:57 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
that is a normal wear pattern of a hi-mileage cam,from the looks of it (as best as i can see)the pattern looks similar to my original 96 cam with 112k on it and the car still ran 13s
Old Aug 23, 2007 | 07:16 AM
gt500pwr's Avatar
OK... the cam has 241 marked on it which i found to be from 94-95 vette. I've attached a few extra pics, much clearer. As you can see the lobes look OK
Attached Thumbnails lt1 cam question-img_4171_5_2.jpg   lt1 cam question-img_4175_6_2.jpg   lt1 cam question-img_4178_9_2.jpg
midge54
Dec 27, 2019 04:14 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
Fronzizzle
Aug 9, 2015 01:15 PM
