runs fine until i hook up est
Old Aug 15, 2007 | 09:18 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
just like the title says runs fine until i hook up est wire. i've set base at 0 , 2 ,4 btc same thing runs really good until i plug in the tan wire.
Old Aug 15, 2007 | 10:30 PM
Re: runs fine until i hook up est
Take off the dist cap and see if the contact on the tip of the rotor is knocked off and pointing sideways.
Old Aug 16, 2007 | 05:43 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
its brand new ,but i checked it anyway and its fine.now what?
Old Aug 16, 2007 | 07:13 AM
What's the history behind this?
Why were you dinking with the "timing" in the first place? Important to know, because since it basically doesn't just up and change itself all by itself out of the clear blue (and therefore is not normally a productive thing to be dinking around with unless it's known to have been disturbed), if it was right before and didn't get moved, then it was still right, no matter what the blinky light shows.
Where was it before?
How did it run?
What happens when you put it back where it was?
What timing cover and crank damper does the engine have on it?
Old Aug 16, 2007 | 10:12 PM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
well, the car use to start and run fine .then one day it refused to start ,then my" gm" buddy said it was the dissy ,since it was still under warranty i just took it back for a new one .well ,anyway ,it was the fuel pump all along .now its doing this.???
theshackle
Mar 5, 2017 06:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
