Price Estimate
Old Aug 16, 2007 | 09:13 PM
ohyaaaZ28's Avatar
Price Estimate
I have a stock 1985 Z28 with the base 305 engine.
If I bring it to a Chevy dealership to do the following:
Complete tune up plugs, wires, cap, rotor, and check and adjust carb if needed
Replace all belts
Drain and refill radiator
Replace upper and lower radiator hoses
Drain and refill transmission and filter (automatic)
Replace engine oil and filter
How much do you think they would charge, will I be able to sit down afterwards? Should I just bring it to a local mechanic?
Everything on the car is original from 1985 and has 29k on it, the car has only been driven about 800 miles in the past 5 years, I thought it may be best to bring it to a dealer so they can ensure its back to factory specs.
I'm I waisting money with the dealer?
Thanks.
Old Aug 16, 2007 | 09:49 PM
Slepewesel's Avatar
Car: 91 Camaro Z28
Engine: 5.0 TPI (LB9)
Transmission: 4L60
Re: Price Estimate
Originally Posted by ohyaaaZ28
...How much do you think they would charge, will I be able to sit down afterwards?
Too damn much.
Thanks.
Yes. Do it yourself in about 3 hours and save yourself a ton of money.
Old Aug 16, 2007 | 11:36 PM
FBird84's Avatar
Re: Price Estimate
well into a thousand dollars. Touching the Trans is over 150 alone. Plus labor and parts. I think the labor now days is around 90$ a hour. But they might be different. I know at my dealership they won't even touch the car because of the age of it, but if they did it would hurt your pocket.
Old Aug 17, 2007 | 12:00 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Re: Price Estimate
Yeah its going to be a lot, especially if you take it to a dealeship to have all that done. All that stuff is pretty easy to do, do you have some friends that could help out? You would be able to knock all that out in a day.
sreZ28
Oct 22, 2015 08:21 AM
bjpotter
Oct 15, 2015 11:07 AM
okfoz
Sep 22, 2015 03:37 PM
ULTM8Z
Sep 16, 2015 09:15 AM
pimprs
Sep 10, 2015 03:34 PM
