A Possible Conundrum?...What injectors do i have?
Old Aug 16, 2007 | 11:11 PM
tguen108's Avatar
Car: 87 GTA
Engine: 5.7L
Transmission: Perfomabuilt
I was wondering if someone knew where i could cross reference the part numbers on my injectors, or heck, maybe someone knows off the top of their head what i have.
The injectors said:
RP 523530
I am only asking because i am doing an engine swap. The guy i bought it from said everything was stock on it. It's a 87' GTA t-tops loaded version, kind of a cool car. Anyhow i was under the assumption that those cars with t-tops cam with 305's, plus the sticker on the front of the car said it had a 305 in it. So i got an older style block, mind you the engine in the car is a new style one piece rear main, and sent it to the machine shop. A day before i go to the shop to pick up my block i pulled the engine out of the car and it had 5.7L stamped on the drivers side rear of the engine.
So to make a long story short I was trying to possibly figure out what other things might have been changed with the engine..possibly the injectors and maybe the ecm were taken out of a car that originally had a 350, who knows. I guess i would just like to know what i am working with.
And what would i have to look at to see if the ecm came out of a 350 car?
Thanks in advance for any help or info!
Tom
Old Aug 17, 2007 | 03:32 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: A Possible Conundrum?...What injectors do i have?
The RP stands for Rochester Products. Every RP number i've seen is 7 digits long. Are you missing one or is that all that's printed on the injector?
Get the part number off the ECM case. Also look at the numbers and letters on the memcal in the ECM. That'll tell you if it's a 305 or a 350 ECM.
Old Aug 17, 2007 | 06:23 AM
That's not the part number. Most of it; but not all.
Could be 5235301, or 5235302.
Both are 20.5 lbs/hr @ 43.5 psi.
Sorry to hear that.... I'd get out from under that thing ASAP if I was you. Those do NOTHING but steer you down the wrong road. In this case, perhaps obscuring the facts about what engine the car has in it; which I can assure you, WIIL NOT respond to your assumptions. It is what it is no matter what you assmue.
What is the 8th digit of the car's VIN?
Old Aug 18, 2007 | 03:23 PM
tguen108's Avatar
Car: 87 GTA
Engine: 5.7L
Ok, found out the whole part number on the injectors to be: 5235301
The whole vin is: 1G2FW21F6HL226386
The number on the ECM: 1227165
And i think i was looking at the prom and this is the info: Delco ABUS 8534
Thanks again
Old Aug 19, 2007 | 12:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Thanks again
The VIN states it was a 305 engine (8th character being an 'F')
The '165 ECM was used on both 305's and 350's
The ABUS calibration is for an '87 305, Pontiac, automatic, federal emssions, 3.23 or 3.27 rear ratio.
The injector number, 5235301, is for 19 #hr injectors as used on 305's.
For the block, the 5.7L (or 5.0L) should be in large raised cast in characters.
RBob.
Old Aug 19, 2007 | 02:01 AM
tguen108's Avatar
Car: 87 GTA
Engine: 5.7L
Thanks a lot for the info. At least now i have more of an idea what i am at least working with.
Thanks again,
Tom
gta892000
Aug 11, 2019 11:16 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
