knock sensor
Old Aug 17, 2007 | 08:27 PM
92rs365hp's Avatar
Car: 2011 dodge journey
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
knock sensor
would a knock sensor on a 91 z28 tpi 305 cause the car to run for 5 min then die and not start??
Old Aug 17, 2007 | 08:37 PM
Re: knock sensor
no
but an ignition module would
Old Aug 17, 2007 | 08:41 PM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
Re: knock sensor
has new ignition mod. and dist.
Old Aug 17, 2007 | 08:46 PM
Re: knock sensor
What's the fuel pressure while it's screwing up? What does the tach read while you're cranking it when it's screwing up?
Old Aug 18, 2007 | 01:52 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: knock sensor
Check the three basics, fuel, air, and spark.
Old Aug 18, 2007 | 07:23 AM
92rs365hp's Avatar
Engine: v6 vvt
Transmission: auto
Axle/Gears: ???
Re: knock sensor
fuel pressure is around 43 psi,,has spark,,air flow is good havent checked tach to see what it pos. it is at yet
Old Aug 18, 2007 | 08:28 AM
Re: knock sensor
So, it's at 43 psi WHILE IT'S SCREWING UP as opposed to when it's working right; and it "has spark" WHILE IT'S SCREWING UP as opposed to when it's working right; and these sparks are nice big fat snappy purple-white ones at least 1/16" in diameter, not little faint weak yellow-blue ones that are hardly bigger than a hair, WHILE IT'S SCREWING UP as opposed to when it's working right; and we know FOR SURE that #1 has spark AT THE SPARK PLUG when it's at #1 firing?
Did you do all these checks WHILE IT'S SCREWING UP as opposed to WHEN IT'S WORKING RIGHT?
Old Aug 18, 2007 | 12:24 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
Re: knock sensor
you need to make sure that the heat compund was put on the new ignition module.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
