is my tach correct
Old Aug 17, 2007 | 11:55 PM
dealerkiel's Avatar
Car: 1992 firebird
Engine: stock 305
Transmission: stock
Axle/Gears: stock
is my tach correct
92 bird 108,xxx 305 automatic completely stock. only had a couple weeks.
cruising at 55 mph the tach reads 1300-1400 rpm. it just seems low to me
Old Aug 18, 2007 | 12:12 AM
Form88's Avatar
Car: 1988 Firebird Formula
Engine: 305 L03
Re: is my tach correct
What does it read at idle? That will, most often be your tell tale sign of a bad tach or the likes . Our car were made with notoriously bad tachs. I had to replace two on the two f-bodies i owned. My 83 t/a read 3 grand at idle, and would sweep the whole gauge, in every gear when i was really around 3-4k. I heard that there is a resistor behind, that goes for a nominal fee of like 2 dollars or so that u can replace, if thats the case. First, try unplugging, and replugging in the tach wire to the dist. or coil. just to make sure the connection is good. U didnt give enough info for me to give u any other scenarios
Jim
Old Aug 18, 2007 | 05:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
What are your rear end gears? If you're running, 2.77's, for example, that range might be about right.
JamesC
Old Aug 18, 2007 | 01:25 PM
dealerkiel's Avatar
Car: 1992 firebird
Engine: stock 305
Transmission: stock
Axle/Gears: stock
i don't have any other problems w/ the tach. it idles at 500-600 rpm. at 70 im running about 1700-1800 rpm.
Old Aug 18, 2007 | 01:31 PM
Gerald Jackson's Avatar
That sounds right to me also. The overdrive helps keep the rpm's low when you are going 55 .
Old Aug 18, 2007 | 01:45 PM
JamesC's Avatar
With 3.23's, my car runs about 2300 at around that speed. I'd say you have highway gears.
JamesC
Old Aug 18, 2007 | 02:10 PM
hattmuber's Avatar
Car: 91`camaro RS
Engine: 5.7l vortec T.B.I.
Transmission: STS 700r4
Axle/Gears: 9bolt-3.27
I think your in the clear that sounds about right it may be a tad low by about a hundred revs or so.
Old Aug 18, 2007 | 02:17 PM
JamesC's Avatar
If factory tachs are within a 100 or so, they're probably doing darn well.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
86maro_252
Oct 10, 2015 06:52 PM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
TrevinE
Sep 14, 2015 03:20 PM
