Car just shut off while driving.
Subscribe
Aug 19, 2007 | 02:13 PM
Well I was giving my car a little open up last night and as I'm accelerating in second the car just shuts down. I had nothing working. I had electrical power but nothing else. After letting it sit for a second, I tried to start it back up and it seemed it had no gas really. It turned over for a second then died. PLease help guys.
also could a bad torque converter cause it to not start?
Reply 0
Aug 20, 2007 | 01:03 AM
Re: Car just shut off while driving.
bump anyone???
Reply 0
Aug 20, 2007 | 01:18 AM
Did you confirm that there was gas?
-Dead battery
-Fried alternator (you can take both into your local parts store to have them checked for free usually)
-Busted fuses
-Clogged fuel filter (drivers side between the rear floorpan and the rear tire. be careful taking this off as the fittings could be rusted and will break the fuel line if too much force is applied. Soak these bolts in PB blaster overnight if they won't give.)
-Dead fuel pump (there are posts here that tell you how to check to see if your pump is priming, search for them), or you could also see if you have fuel at the fuel rail. On the passenger rail there is a schraeder valve, depress it with a screwdriver and see if fuel comes squirting out. Try this with the key in the 'on' position. No fuel = no pumpy worky.
Those are a few things that come to mind right away.
Reply 0
Aug 20, 2007 | 01:49 AM
Well the car will start for like half a second then it dies. i have brand new battery alternator and a fuel filter. so i been thinking its a fuel pump
Reply 0
Aug 20, 2007 | 02:00 AM
Try the schraeder valve on the fuel rail then. Better yet, see if you can rent or buy a fuel pressure gauge from autozone or napa, etc. See what your pressure is with the key in the on position.
Reply 0
Aug 20, 2007 | 07:40 AM
Gauge is much safer and better. Squirting still occurs even as low as 6psi. That's way too low to run the engine but it'll still squirt out the schraeder.
Reply 0
Aug 21, 2007 | 01:24 AM
ok 2 things. What should be my psi and where will i hook up the gauge?
Reply 0
Aug 21, 2007 | 10:50 AM
Should be between 45 to 50psi. Gauge goes on the fuel rail on the passenger side, there is a valve there that sticks out. It is located closer to the rear of the fuel rail.
Reply 0
Aug 21, 2007 | 10:53 AM
Stock pressure is ~42-43.
Reply 0
Subscribe
