What do you guys set timing at ?
Old Aug 19, 2007 | 02:43 PM
Preluder77's Avatar
I have a 1986 iroc z with a 305 and a factory carb, it is also a factory 5 spd. I was wondering what is a good timing set? It seems to run a little hot around 220 in traffic with the a/c off? and even when it is running around 180-190 and i turn the car off it diesls alittle bit ?
Thanks for any help
Old Aug 19, 2007 | 08:29 PM
Preluder77's Avatar
Re: What do you guys set timing at ?
Any 1 ? i know the factory setting is 0 degrees. i was just wondering if most people leave it at that or if they have sucess advancing it alittle to like 4 degrees or so ?
Old Aug 20, 2007 | 02:23 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
6 degrees seems to be a good number. If its dieseling on shutoff then you've got a lot of carbon in the combustion chambers.
Old Aug 20, 2007 | 07:33 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I run my "stock 88" off 6 degrees.
My "not so stock" 92 gets 8.
Old Aug 20, 2007 | 11:10 PM
Preluder77's Avatar
hey thanks for the help im gonna do alittle tunning with the timing to see how it acts. Also this car is bone stock. Whats the best way of getting rid of all the emissions and smog stuff? Does the computer get pissed about this?
Old Aug 21, 2007 | 01:56 AM
Kevin91Z's Avatar
The best way is to leave it there. Removing, disabling, tampering, or otherwise modifying your stock emissions equipment is a violation of FEDERAL laws, regardless of your state or local emissions testing requirements. It doesnt hurt anything having it there, other than a cluttered engine bay. But leaving it there certainly helps keep the air clean and promotes responsible hot-rodding.
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
jharrison5
Aug 19, 2015 05:53 PM
mx127
Aug 10, 2015 08:13 AM
