Oil pressure problem
Old Aug 21, 2007 | 11:19 AM
Kjohn21365's Avatar
Car: '88 Formula Firebird
My '88 L98 has been showing low oil pressure on the gauge when the car is warmed up. The pressure rises with increased rpms - but drops way down at idle or coming to a stop. Has no problem holding pressure after a cold start. What could be causing this? I never noticed the car doing this before and seems to drive the same as ever.
Old Aug 21, 2007 | 12:06 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Re: Oil pressure problem
I wouldn't trust the electronic oil guage. Mine does the same thing. At idle the oil pressure is suposed to read around 30 psi and while driving up to 60 psi. I would hook up a manual oil pressure guage just to make sure your electronic oil guage is reading correctly
Old Aug 21, 2007 | 01:04 PM
Kjohn21365's Avatar
thanks
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
