VATS questions! Please help
Old Aug 21, 2007 | 07:44 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Transmission: Automatic
Axle/Gears: stock(what could be better!!)
I need to know exactly where my vats box/relay is. I have a 1991 Firebird v6 5 speed. I know in some of the f bodies they are located in different spots.. anyone know exactly where it is at?
Old Aug 22, 2007 | 12:27 AM
Vader's Avatar
Re: VATS questions! Please help
Old Aug 22, 2007 | 01:53 AM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
thanks man
Old Aug 22, 2007 | 02:05 AM
Vader's Avatar
In case you don't find a problem at the VATS module, this might help:
VATS System
Old Aug 22, 2007 | 02:45 AM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
i've tried all the resistances, i did it in about 3 days....i got a busy schedule....i am pretty sure i did it right, just run them inline with the black/white wire right? between the connector and the module right?theres a purple and a black/white wire did i do it right?
Old Aug 22, 2007 | 11:36 AM
Vader's Avatar
The resistor should not be installed "inline" (in series) in the BLK/WHT wire. That will only add resistance to the circuit, and still require contact to the key resistor pellet. The resistor you would install should be installed IN PLACE of the key resistor pellet, between the BLK/WHT wire and VIO/WHT wire. The wiring connector to the ignition lock cylinder will be left disconnected, so the VATS module will read only the resistor you've installed.
Old Aug 22, 2007 | 12:09 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
not sure i follow you....you got an example, perhaps you can draw it in paint on your pc and send it to my email...you dont have to, but if you do...my email is: w_mortell@hotmail.com
Old Aug 22, 2007 | 07:40 PM
Vader's Avatar
Instead of that, let's keep it all here for others to see in case they ever search.
Old Aug 22, 2007 | 11:47 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
so i have to stop the wires at the steering column connector, put the resistor to the vio/wht AND blk/wht wires? Just use resistors to put the two wires together? Like:
violet/white wire--resistor--black/white wire.....
_____________ ------ooo------_____________
like that? Sorry Im makin this so difficult man, I am a bit flustered lately!
stalkier
Dec 6, 2015 11:25 PM
WIzmo
Aug 30, 2015 02:30 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
stalkier
Aug 13, 2015 12:59 PM
