HELP!!! key wont turn to start.
Old Aug 22, 2007 | 12:20 PM
Jammen Firebird's Avatar
please help I went out this morning and moved my 83 trans am into the drive way and when I went to move it up into the garage a few min later the key wouldnt go all the way to the start position. it will turn to acc and just a very little bit more but not all the way to start so i cant start the car it feels like its binding up. whats going on also it did it to me alittle yesterday but i just messed with the key then it went to start and started the car. now today nothing
Old Aug 23, 2007 | 05:48 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: HELP!!! key wont turn to start.
Try lubing the key up with WD-40 and jiggling it around in the cylinder. Sounds like you may be in need of a new ignition cylinder.
Old Aug 23, 2007 | 04:54 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Try moving the steering wheel wile turning the key.
Old Aug 23, 2007 | 05:13 PM
well i used a hole bunch of wd-40 and all i had to do was push < in pretty hard on the key then turn it and it stays in farther then it works but if i dont push in it wont turn all the way. ( and when i mean im pushing hard on the key its to get the cylinder that holds the key to go in farther) Thanks for the help!
Glowsock
Jul 24, 2025 03:15 PM
Glowsock
Aug 31, 2015 09:01 PM
WIzmo
Aug 30, 2015 02:30 PM
Bryan F
Aug 18, 2015 02:28 PM
ZsTransAm
Aug 11, 2015 07:30 PM
