Gear puller questions!
Old Aug 22, 2007 | 05:32 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Bought a gear puller so I can take my crank timing gear off, It didnt come with directions, so I used it, I got the gear to the edge and I realized it was stripping the balancer threads, and It would come off an more. Did I get the wrong puller? what should I do now? Im kind of pissed and want the motor in the car by september.
Old Aug 22, 2007 | 06:41 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: Gear puller questions!
Might help if we knew what kind of puller you tried to use.
Old Aug 22, 2007 | 06:47 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Do you have a pic of the puller u used?
This is one simular to what i use. I welded an old socket on the end of it so it dosent go into the crank.
Old Aug 22, 2007 | 07:01 PM
I screw a short bolt into the crank to give the puller screw something to press against.
Old Aug 22, 2007 | 07:28 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
i had a 3 finger puller,
I tried putting a bolt in the crank and the bolt seemed to deeper into it!! I guess I need to fix the crank, but how?
Old Aug 22, 2007 | 07:37 PM
Must not have been the right size or thread, or not screwed in all the way....
If the threads are farkled, it's Heli-Coil time.
Old Aug 22, 2007 | 07:42 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
Ok, i got the gear off, I ducttaped an old lifter to the end of the crank and then used the puller, Im gonna get heli-coil, How do u put on a new gear? heat the gear up and put it on?
Old Aug 22, 2007 | 08:44 PM
Yes, that works well; heat it GENTLY, just until a bit of oil on it starts to smoke. No hotter than 400° or so. Then tap it on if necesary with a brass drift.
Old Aug 22, 2007 | 10:00 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
I assume we are talking about a SBC...
Of the couple I've done they all went on without heating them. I just gently tapped them on with a small hammer around the whole gear. Comp also makes a better tool for installation that uses a stud in the end of the crank, and uses a nut to pull up on a spacer to push the crank gear on.
junkcltr
Aug 2, 2019 11:12 PM
beastin91rs
Oct 9, 2015 07:38 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
