Fuel injector question
Old Aug 23, 2007 | 04:29 PM
PONTlACSpeed's Avatar
Car: 1989 GTA
Engine: 5.7
I have a simple question will a set of 24lb injetors off of a 1987 camaro 5.7 tpi fit on my 1989 trans am 5.7 tpi? thanks
Old Aug 24, 2007 | 07:48 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Fuel injector question
Yes. But you'll run a bit rich without some prom tuning.
Old Aug 24, 2007 | 08:13 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
For starters, if the injectors are stock on the 87 they are 22lb and NOT 24lbs.
Old Aug 24, 2007 | 01:29 PM
Car: 1989 GTA
Engine: 5.7
no they are not stock they were relpaced with 24lb and have 600 miles on them
Old Aug 24, 2007 | 01:36 PM
DJP87Z28's Avatar
Try them out and see if the ECM can adjust for the larger injectors. If not then you may require a new chip.
Old Aug 27, 2007 | 03:21 PM
Car: 1989 GTA
Engine: 5.7
what size injectors came on my 1989 trans am gta 5.7 tpi, is it 21 or 22 lbs or something else?, i think ill just look to get the same ones that are stock just need to know before i go looking. thanks
Old Aug 27, 2007 | 03:52 PM
DJP87Z28's Avatar
These are the only stock injectors used on 3rd gen TPI's all years.
305 TPI = 19#
350 TPI= 22#
Old Aug 27, 2007 | 03:57 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
I have heard that the 89-92 TPI 305 use the #22 but with a lower fuel pressure.
Old Aug 27, 2007 | 05:10 PM
DJP87Z28's Avatar
You heard wrong. Have your hearing checked and also at the same time check your facts.
Old Aug 27, 2007 | 09:38 PM
Toehead's Avatar
There is a difference between correcting somebody and being an *******. Maybe the same guy that checks my ears can teach you some respect and some manners.
For the record, here is where I "heard" that little tidbit.
http://www.scotthansen.net/customerinfo.html
Old Aug 28, 2007 | 05:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Wow.
While I agree that a higher pressure will produce somewhat of a better spray pattern; GM kicked these TPI's out of the factory with 43.5psi.
Old Aug 28, 2007 | 06:25 AM
DJP87Z28's Avatar
Not in your lifetime and keep your ******* comments where the sun dose not shine. Now this is correcting someone who is off base with a reply. When you post be sure of the facts and not I heard.
Old Aug 29, 2007 | 05:04 PM
Car: 1989 GTA
Engine: 5.7
I found a set of Accel 21#lb injectors, would i need any modifications after putting them in or just a simple swap? sorry not to familiar with the fuel injection system. Just looking to switch them out and be done with it. thanks
Old Aug 29, 2007 | 06:08 PM
Toehead's Avatar
You are a rude individual and I wont waste my time or drag myself to your level by fighting with you.
DJP87Z28's Avatar
They should work,but you maywant to raise the fuel pressure to 45PSI (need a adjustable fuel pressure regulator for this).
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
