Running too rich?
Old Aug 27, 2007 | 11:51 AM
nbays1975's Avatar
Car: 88 GTA
Axle/Gears: 10 bolt rear w/3.73 richmond gears
Running too rich?
My car is still not running right! The fuel pump went out and I replaced that. The fuel pump would stop working properly when it got hot. However, when it was cool, the car ran great. Now the car is running too rich. When I start it, it won't even stay running and sputters and makes all kind of noise. After I drive it for a while, it smooths out. However, If I give it too much gas at lower RPMs it hesitates again and my A/F ratio gauge reads rich. One thing to note. I had a new exhaust system put on at nearly the same time that I changed the fuel pump. The original cat was open. All the guts were removed. The new cat is high flow but not gutted. The engine is built and cammed (350 to 400 hp) and I believe it has an aftermarket chip, but I don't know for sure. So, could the new cat have screwed up the tuning on the car so that it runs rich all the time?
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
